done this on other years, i'm sure it shouldn't be too dificult.
anyone done this yet
At the PCM (I cannot remember which connector is 175B) there will be 2 wires you can tap to control the fan with a switch. One is Green/Blue in pin 34, which is the low speed control, and the other is White/Blue in pin 18 of the connector, which is the high speed control of the fan. The connector is a 70 pin.
Tap into the wire of your choice, either low speed or high, run that wire to one side of your switch, and run the other to chassis ground. When the key is on, flip your switch to the on position, and your fan will engage.
I dont see it doing a whole lot if you arent also spinning the water pump. With an electric pump it would be beneficial.
actually an elec fan especially our high speed ones do alot to cool down. you have to remember, you not just cooling the coolant, your cooling the intake, the blower, the blower tubes, etc...
Yeah, i get that. But all the coolent in the motor will still be very hot. An electric water pump does wonders. That how I had my drag radial race car setup and you could cool thing thing way down in a matter of seconds. Im sure its beneficial, just would be better with an electric water pump.
Convection causes coolant to circulate even when the motor is off.
u were right on. worked great
Im not sure, there is a number at each end of each row.
Isn't it better to do a thermostat that goes off at a lower temp?
