WOW tire hop
97camastang06
Nj
Went to the track last weekend. for some reason between 2-2500 rpms my car has massive tire hop untill 2nd gear. about 28-3000 rpms my car was fine..LCA here I come
NA-Stang
AMC #8 aka "The Jockey"
Might as well pick up a UCA and LCA Relocation brackets while your at it...
97camastang06
Nj
Yea if I can find a good deal on both I def will but def lca for my next track visit
dysan
Dis-Member
Williamstown, N.J.
Definitely do both. The LCA's did lessen my wheel hop alot, but it wasn't totally gone until I also did the UCA.
97camastang06
Nj
Do you think I can toss that kit on with a jack and hand tools or would I need a lift
Meridian, Idaho
I just added the UMI adjustible upper with roto joint and lower fixed with roto joint, nice stuff, I wish I would have purchased a multi hole upper mount at the same time, make sure you figure out how to remove you rear seat before you start the upper. installing both upper and lower took maybe 2 hours using air tools, floor jack and stands, would have been quicker if I would have know how to remove the rear seat to get to that bolt.
