WTB GT350 Voodoo Oil Restrictors
Try L&M Race Engines, Hatboro PA
swflastang05
Back for More
N. Ft. Myers, FL
Check with local machine shops that work on ford engines.
Thx for the suggestions unfortunately my luck prevails, nobody local had a clue, even contacted Steve@ Tasca, he had a hell of a time finding the parts, ended up having to call Ford Performance, they didn't even know, the tech supervisor had to get involved, finally they figured it out, I think, the parts had to be ordered of course, will post up when I receive if they're correct I'm sure I wont be the only person that ever runs into this,
86GT351
Sunny South Florida
Should have called Tim at MPR racing. Probably has them in stock with the amount of Mod Motor builds he does.
swflastang05
Back for More
N. Ft. Myers, FL
maybe so, I'm beginning to think I should have called him for several other things also vs. the shop that I did reach out to. I'll reserve any further comment on that for now though, knowing the really weird times were in..
86GT351
Sunny South Florida
Did you find what you need?
swflastang05
Back for More
N. Ft. Myers, FL
I finally found the 2.2mm size, which happen to be the same as Coyote heads here's the part
Still nothing on the OEM 5.2 1.2mm versions, even from various dealers, I had to contact Ford Performance to find these, and they eve had a hard time, so here's the info if anyone else ever needs it. Got mine from Steve @ Tasca.
