Wtb pig tails
Jason
Fort Riley, KS
Need some 05-09 pigtails guys. Specifically all the front lights...i.e. headlights, side marker lights, and blinkers. Also need the female tps sensor (pretty sure that's it, it's the harness that connects to the p/s of the t/b). I don't remember if that's the tps sensor or if it's the connector on the d/s. Regardless, I need the one from the p/s. Also looking for coil pack pig tails.
Thanks
Jason
Fort Riley, KS
Used or new. Just as long as the used ones have no damage an have about 6" of wire. I'll pm the guy on the f/s add. Thanks guys.
supadave
Virginia Beach, VA
Been trying to PM you, I've got em.
Headlight connectors are missing locking tabs, just found this out and they never gave me a problem. Cool connectors are new, just soldered into my harness. They're 3-4 inches and the rest has plenty of wire.
Jason
Fort Riley, KS
No, thank you. I Need these because my past projects have left me with little wire on those pig tails. I'm doing a wire tuck and I'm trying to clean all my past modifications up. The clips don't matter really, I can just depen the terminals and just use my old connectors. All I need are the wires with the terminal ends. This will make it a lot easier on me and my wire tuck look more professional and clean. I need the coil packs for the actual clips because they broke the last time I depinned them. Again, I can just depin the wires and just use the new clips so I don't have to solder these on.
