Bobby
turbo gt about to go fast
as the title says. looking for forged stroker crank and forged rods.
Rods are rated to 1250 and I've seen them go 1300. Here's your problem: anytime you're over 1000 hp the rod/stroke ratio on a stroker engine becomes problematic. No longer are you using the stroke for extra torque. You'll end up beating the rod bearings all to shit and hammer the engine. Rod angularity causes the crank to whip and twist in the saddles.
what i am trying to do is...
1) have the fastest 3v on 1 power adder and all dont on 93 octane.
2) and also want to have the most hp on a 3v single power adder on 93 octane.
3) then i want to be able to turn up to poost to 30-35 psi and make all kinds of power and really run some good times.
ok thanks or should i go to the biggest mod motor i can go. like this one but i wouldnt buy it from them. the 351 cu" motor from mmr. check it out
5.4l Navigator based engine. Navi block, Navi heads, Navi timing cover, Navi Valve covers, Lightning Crank
ModMax Billet rods
CP pistons
Custom Billet cams
Double Valve springs with titanium retainers
ModMax 1 mm over stainless steel valves
Heads are completely ported
Arp Head and Main studs
Moroso oil Pan
Cobra Oil pump
Riechard Racing 5.4 to 4.6 adaptor plates
Custom 01 cobra "short runner intake"
Engine has been balanced
