Yaw sensor circuit chassis code?
Seer
Picked up car from having an engine swap, it is a 2012 GT500. Getting a blinking abs light and TC light. Chassis code is regarding a yaw sensor. ABS module was also replaced by the dealer (don't ask), but this issue is still persisting.
Most likely unrelated but also seeing P0100, MAF Circuit error
killr3v
Hector G.
Katy, TX
Isn't the use sensor in the steering column? Could it have been damaged when the steering shaft was disconnected?
Seer
Could be, or the steering shaft was put in backwards.
killr3v
Hector G.
Katy, TX
You won't be able to tell if the sensor is good just by looking at it. I suggest checking resistance against the service manual to see if it is within spec.
weather man
Persistance Is A Bitch
MN
That member no longer needs our help.
