Looks great. I should be going this route.
I had BC Racing on my SRT-4, great coilovers were better than the K&Ws I had.
DRock that is way too low for my tastes, but generally looks good. Way better than the 4x4 ride height on the latest stangs.
I will be invading Oahu this weekend, I will keep an eye out for your car if you are on that island...
So after a few hundred miles on these coilovers, I can say that they HAVE softened up a bit. Not as harsh of a ride as first install. The front is still a little low but I'm learning to navigate the roads and have yet to get stuck anywhere.... There is a rather loud clunking noise in the rear end of the car at slow speeds over rough roads that almost sounds like something is loose...I checked everything and cant find a loose bolt or nut anywhere...
This may sound dumb but, is the spring seated correctly and preloaded?
This may sound even dumber.....
I have no Idea....
Check.
And how do I asjust preload on a solid axle...??
