2012 questions
gangaskan
just bought a 12 v6 and here are my questions
its a 6 speed manual, first is a whore to get into, it has what i believe is just a hurst knob and arm, but the shifter feels extremely tight, is that normal? i only drove one other 197, but it was a 10' gt.
my passenger door card leather is loosening, but it looks rough, is there somewhere where i can buy the matching leather to re glue?
im looking at radio stuff now, i bought the scoche kit and already have a joying android unit. can the front speakers take 5.25? i have non shaker, no sync. pretty basic.
are there things i should look out for? i checked my vin to make sure no tsb's were needed.
totaljustice
The only question I can answer for you is that the MT-82 in the 12 to 14 was notorious for hard shifting into first and second gear. There was a Ford TSB out for it somewhere you can probably find on the net. The fix was changing the tranny fluid for something different. I ended up putting in Royal Purple Syncromax myself and that solved the issue. I should also mention that the hard shifting usually lessened a lot when the transmission got warm so if you still have problems after everything reaches operating temperature it would probably be something else. Hope that helps.
