Only slot the specified amount or you might be in trouble with the rules (probably not an issue locally, but could be if you went even to a divisional).
The Hoosier tires are built different than most street tires. I have run 305's on 9 inch rims, 295 and 285 on 8 inch rims with no problems. They are a bit cantilevered which allows that. When I ran an RX8, the 285 and 295 Hoosiers wore better than the 245's all on the same 8 inch rims. You need to take care of Hoosier tires or you will hasten their demise. No quicker way to ruin a Hoosier than to burn too quickly into a corner and have that expensive rubber wear right off of the cords as you understeer. You have to be nicer to them than the good street tires like the R-S3.
You definitely want A6's and not R6's. If you are worried about cost and wear, get V710's instead--though it should be noted that V710's are a lot more difficult to mount on rims thinner than for which they were designed.
Long story short, I wouldn't hesitate to run those tires.
