05-10 Mustang Fuel System Wire upgrade kit
05-12 Mustang Fuel System Wire upgrade kit
This wiring upgrade has been proven to drop fuel pump duty cycle by 10% and will allow yout to get more out of your fuel system. A cheap and efficient must do mod for anyone looking for more fuel. This kit runs 10 gauge wire directly from the battery through a relay to the fpdm to get the most out of your fuel setup. Kit is 100% complete with everything you need for a complete and clean install.
$35, free shipping in cont US.
This setup can also be used in conjuction with a bap if you choose to use one.
Have the battery in the trunk or need some custom wiring for your setup? I can build these kits custom for your car for no extra charge.
Kit includes:
-10AWG INLINE HEAT/WATER RESISTANT FUSE HOLDER WITH 30AMP BLADE FUSE
-16FT 10AWG RED HIGH CURRENT PRIMARY WIRE
-BOSCH 40AMP AUTOMOTIVE 5 PIN RELAY
-1FT 10AWG BLACK GROUND WIRE
-1FT 10AWG RED HIGH CURRENT PRIMARY WIRE OUTPUT TO FPDM
-1FT 16AWG INPUT WIRE FROM FUEL INERTIA SWITCH
-MISC: -3M TAPE
-SELF TAPPING SCREW
-2 PIECES OF HEAT SHRINK TUBING
-4 ZIPTIES
-DETAILED COLOR INSTALLATION INSTRUCTIONS (CAN ALSO BE EMAILED TO YOU)
Order
Gray1622
Fuel System wire upgrade kit and pump connectors.
Paid.
Kit complete.16Jan
Ships Tuesday. 17Jan
hightechrdn
Do you have something similar worked up for the 2011+ 5.0 cars?
Sent from my NookColor using Tapatalk
GT500KR
Quad Cities, IA
Need. Confirmation. I'm doing the DOB manifold swap. Bought the stealth pump. So I have to upgrade the wiring too? But do NOT need a Bap right?
If your on the stock block, yes that pump and wire upgrade is all you need for 500rwhp, no bap needed.
88_50
TX / Afghanistan
Bump for a great kit. This kit has pics making it super easy to install! I have it on my '06 Saleen, and highly recommend it for everyone.
Thanks Jeremy!
Saleen S281
Texas
I got the pump kit and wiring upgrade from Jeremy, very knowledgeable, its getting installed next week. Bump for a good guy!
