No comparison really. Standard anti-seize is only good for around 1,400 to 1,600 degrees. Nickel anti-seize is hi-temp and rated from 2,400 to 2,600 degrees. The nickel anti-seize will withstand the combustion chamber temps if you are using it on your 4.6 spark plug grounding shields, the standard parts store stuff will burn off quickly.
