SCT livelink and fuel pressure??
redfirepearlgt
FYI - only a maximum of 20 points in a cfg file. SCT cannot do more than 20 points. I prefer datalogging with my laptop through the SCT. My tuner seeks 28 points of information. Once the cfg is made its a cinch. Plus the 2.5.X update sync's up much quicker than the previous versions. Data is not garbled, and histograms also make sifting out 411 much easier.
46addict
13726548
Lawrenceville, GA
My tuner had me use PRES DROP F INJ in Livelink to log delta pressure. I don't know if there's a way to log pressure off the rail. Maybe Aeroforce or something fancy has a feature that converts fuel psi to volts, in which case you can use an analog input on the SCT Firewire and have it record in Livewire. You would then convert volts back to psi using a formula so it's meaningful to the user.
