I'll sell you my Rotrex kit off my old 2006. Comes with a lot of extra stuff and good parts. It made good power -- car trapped high 120s.
How much boost was it set up for? Any supporting mods besides the typical fuel upgrades?
To answer the OP, a big bore build with heads/cams etc makes sense for a road course car. For starters the added weight of supercharger/turbo components at the nose of the car can upset the balance in the corners and you'll be looking for ways to keep inlet air temps (among other critical temps) at a decent level.
For a street/strip car, boost/nitrous will net the biggest bang for the buck. If you decide to go this route, hold off on the cams. Low boost setups will work just fine with stock cams, and some cams don't play well with superchargers/turbos so you need to figure out what your final power goals are. Otherwise you'll waste time & money going from one setup to another.
Are the On3 turbo kits a good quality product or are they problematic? I just called another local speed shop and they said they don't deal with them. They said the turbo kits he installs and sells are more expensive than a supercharger. Then he told me if a turbo kit is that cheap it can't be any good and you get what you pay for.... So this is what I'm dealing with on my end. LOL! Lack of good local performance shops and they want Me(the guy that knows nothing about FI) to look everything up, buy it and hand it to them to install.
.......may have been referring to heat soak issues that come up when you overspin them, but that can happen with any supercharger.
So after reading this thread and a few others you guys are saying stock internals will only handle about 450-475 hp and less than 10 psi for boast correct? I’m wanting to get a little more HP out of my stock 05. And I’m wanting a side mounted supercharger. I’ve got a local tune shop that’s going to be sping the tuning on my Dad’s GT 500 so that’s not an issue.
welcome to 2007............
side mounted SC?? do you mean centrifugal blower?
PDs can be side mounted, never heard the term before used like that.
Wow. Never seen that before. Pretty sure that is an Eaton M122 from a gt500.PDs can be side mounted, never heard the term before used like that.
