S197 Mustang Forum - S197Forum.com
Go Back   S197 Mustang Forum - S197Forum.com > Mustang s197 Tech Forums > 2015+ S550 Mustang 5.0L Tech
Reply
Thread Tools Display Modes
Old 03-27-2015, 11:10 AM   #1
Official Site Vendor
Jared@Lethal's Avatar
Jared@Lethal is on a distinguished road
Default Diode Dynamics Switchback Bulb Installation
Took a few minutes yesterday to install the new Diode Dynamics Switchback bulbs on our 2015 GT.
Click the image to open in full size.
For anyone who isn't familiar with how a switchback works here's what they do. When this bulb is on as normal, with your parking lights or headlights, it shines a nice, pure white color. Anytime you activate the turn signals, it flashes bright amber.
The install is super easy and only take a few minutes per side. I was able to do the install without a lift or jack stands.
The first step was to turn the tire so that I could remove (3) of the clips which hold the fender liner in place. Starting with the lowest one and moving on upwards I used a flathead screwdriver to pull the center pin of the clip out. Once the center pin on the clip is in the outward position you can pull the entire clip out.
Once all 3 clips were removed I pulled the fender liner away giving me enough room to reach the connector on the back side of the turn signal assembly.
Turn the connector counter clockwise and gently pull the connector with the factory bulb on it out of the turn signal housing.
Pull the factory amber bulb out of the socket and replace it with the Diode Dynamics bulb.
Re-insert the connector with the Diode Dynamics bulb back into the turn signal housing and turn it clockwise locking it in place.
Install the 3 clips back onto the fender liner securing back in place.
Repeat the same installation on the other side of the vehicle and you're done.
Here's a pic of the car with the factory amber bulb installed with the running lights on.
This is with the Diode Dynamics switchback installed with the lights on.
Here's the Diode Dynamics switchback bulb with the turn signal on.
http://i564.photobucket.com/albums/s...psyy0xrs17.gif
These bulbs are now IN STOCK and available here at Lethal Performance.
Follow the link below or simply give us a call at 561-753-8105 and we'll be glad to assist you.
http://www.lethalperformance.com/sho...l-led-kit.html
__________________
LETHAL PERFORMANCE, INC.
877-2LETHAL
Whipple Supercharger's Largest US Distributor
MCLEOD, Spec, Ram, Fidanza, Centerforce Always in Stock!
Steeda, BMR, MM, UPR, CHE -Suspension
Jared@Lethal is offline   Reply With Quote
Old 03-27-2015, 02:42 PM   #2
RSKtakR
RSKtakR's Avatar
RSKtakR is on a distinguished road
Default
is it possible to get rid of that 2nd orange light that is on in that housing as well or is the housing just orange?
__________________
2015 DIB Performance Pack GT w/ Recaro's.
SOLD:Grabber 2013 Boss 302, Torsen, Recaro's, #1804.
SOLD:2011 GT 5.0 6spd
RSKtakR is offline   Reply With Quote
Old 03-27-2015, 04:06 PM   #3
bossmanpena
Team OverDrive
bossmanpena is an unknown quantity at this point
Default
hey the 2nd bulb is a led , model 194
__________________
http://www.s197forum.com/forum/image.php?type=sigpic&userid=13737&dateline=134207  8353
3521 Oorah Semper Fidelis
bossmanpena is offline   Reply With Quote
Old 12-02-2015, 10:51 AM   #4
MSgt46270
MSgt46270 will become famous soon enoughMSgt46270 will become famous soon enough
Default
Your link isn't working, at least for me?
MSgt46270 is offline   Reply With Quote
Old 12-04-2015, 12:02 AM   #5
Grabber5.sl0w
Grabber5.sl0w's Avatar
Grabber5.sl0w is an unknown quantity at this point
Default
It's because DD pulled back that gen of switchbacks due to some quality issues. I think because some people we experiencing hyper-flashing. Anyway, the new gen is set to release in the next week or so.
__________________
2016 Mustang GT Premium - CompO - Build Thread - flickr
Instagram: CompO5sl0w
Daily Driver: '15 Rubicon JKU
Grabber5.sl0w is offline   Reply With Quote
Old 12-27-2015, 11:02 PM   #6
Greg Hazlett
Stepping on the Pink Bus
Greg Hazlett's Avatar
Greg Hazlett will become famous soon enoughGreg Hazlett will become famous soon enough
Default
Received and installed!
__________________
If common sense were truly common there would not be the need to talk about it.....
Greg Hazlett is offline   Reply With Quote
Old 03-10-2017, 06:23 PM   #7
ValK
ValK is an unknown quantity at this point
Default
Two questions. Do these work in 05 GT? And do you require a resistor to prevent hyper flashing? Or does the new version come with?
ValK is offline   Reply With Quote
Old 03-11-2017, 07:03 AM   #8
Iceman62
Bullitt 6005
Iceman62's Avatar
Iceman62 is an unknown quantity at this point
Default
Diode Dynamics is awesome...those look great & I'll have to relay over to my son. He's got a 2016 CA-Special & wants to swap some lighting. Thanks!
__________________
32-Degrees = Iceman is "In the House"
MSgt, USAF (Retired)
Iceman62 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Ad Management plugin by RedTyger
