Diode Dynamics Switchback Bulb Installation
Discussion in '2015+ S550 Mustang 5.0L Tech' started by [email protected], Mar 27, 2015.
  1. Jared@Lethal
    [email protected] Official Site Vendor
    1,067
    May 29, 2007
    Took a few minutes yesterday to install the new Diode Dynamics Switchback bulbs on our 2015 GT.
    [​IMG]
    For anyone who isn't familiar with how a switchback works here's what they do. When this bulb is on as normal, with your parking lights or headlights, it shines a nice, pure white color. Anytime you activate the turn signals, it flashes bright amber.
    The install is super easy and only take a few minutes per side. I was able to do the install without a lift or jack stands.
    The first step was to turn the tire so that I could remove (3) of the clips which hold the fender liner in place. Starting with the lowest one and moving on upwards I used a flathead screwdriver to pull the center pin of the clip out. Once the center pin on the clip is in the outward position you can pull the entire clip out.
    [​IMG]
    [​IMG]
    Once all 3 clips were removed I pulled the fender liner away giving me enough room to reach the connector on the back side of the turn signal assembly.
    [​IMG]
    Turn the connector counter clockwise and gently pull the connector with the factory bulb on it out of the turn signal housing.
    Pull the factory amber bulb out of the socket and replace it with the Diode Dynamics bulb.
    Re-insert the connector with the Diode Dynamics bulb back into the turn signal housing and turn it clockwise locking it in place.
    Install the 3 clips back onto the fender liner securing back in place.
    Repeat the same installation on the other side of the vehicle and you're done.
    Here's a pic of the car with the factory amber bulb installed with the running lights on.
    [​IMG]
    This is with the Diode Dynamics switchback installed with the lights on.
    [​IMG]
    Here's the Diode Dynamics switchback bulb with the turn signal on.
    [​IMG]
    http://i564.photobucket.com/albums/ss88/LethalPerf/turnsignal_zpsyy0xrs17.gif
    These bulbs are now IN STOCK and available here at Lethal Performance.
    Follow the link below or simply give us a call at 561-753-8105 and we'll be glad to assist you.
    http://www.lethalperformance.com/shop-now/vehicle-selector/ford-mustang-v8-gt/2015-ford-mustang-gt/lighting/led-replacement-bulbs/diode-dynamics-2015-mustang-switchback-turn-signal-led-kit.html
    [​IMG]
  2. RSKtakR
    RSKtakR Senior Member
    1,139
    Sep 19, 2007
    Raymore MO
    is it possible to get rid of that 2nd orange light that is on in that housing as well or is the housing just orange?
  3. bossmanpena
    bossmanpena Team OverDrive
    452
    Jan 26, 2012
    New Jersey
    hey the 2nd bulb is a led , model 194
  4. MSgt46270
    MSgt46270 Senior Member
    6,054
    15
    Apr 6, 2007
    San Diego, CA
  5. Grabber5.sl0w
    Grabber5.sl0w forum member
    1,379
    Jul 22, 2011
    Martinsburg, WV
    It's because DD pulled back that gen of switchbacks due to some quality issues. I think because some people we experiencing hyper-flashing. Anyway, the new gen is set to release in the next week or so.
  6. Greg Hazlett
    Greg Hazlett Stepping on the Pink Bus
    23,385
    21
    Nov 2, 2009
    Chesapeake, VA
    Received and installed!
  7. ValK
    ValK Junior Member
    25
    Jan 28, 2017
    Calgary, AB
    Two questions. Do these work in 05 GT? And do you require a resistor to prevent hyper flashing? Or does the new version come with?
  8. Iceman62
    Iceman62 Bullitt 6005
    274
    Feb 5, 2017
    NE
    Diode Dynamics is awesome...those look great & I'll have to relay over to my son. He's got a 2016 CA-Special & wants to swap some lighting. Thanks!
Share This Page
