I currently have the Meziere 20gpm pump; I am thinking about replacing it with something else. I'm not too impressed with it and would prefer a better mounting option.
May look into getting the 4.8 gpm HD Bosch unit...
According to the test results above, it flows more than my Meziere 20 gpm pump.
How reliable are those test results?
I'd say they were reliable. At least they used a megabuck, calibrated flow meter.
Electric Water pumps are no different than electric fans and squirrel cage blowers..... you can't go by max no load numbers.
EG: with squirrel cage blowers, they are rated in cfm.....in free air, with no back pressure. The better quality units will graph the cfm vs back pressure on a graph. With NO back pressure you get max cfm. With a big enough back pressure, the cfm will drop to zero (called cut off).
Electric fans are notorious for crapping out into the slightest bit of back pressure.
(Now you know why 'electric superchargers' don't work....no pressure behind em).
Electric water pumps will be no different. The fellow took each unit, and graphed GPM vs back pressure. "20 gpm" with no back pressure is a meaningless number to quote.
Use the IC pump from the 2013+ GT-500. If you really wanted to flow a ton of water, use two of em...nose to tail. You could even put em at opposite ends of the loop.......... or at any point in the loop.
IMO, increasing the flow rate won't do much good unless the HE is capable of dumping the heat...otherwise you will just be circulating hot water. The IC extracts the heat..and the HE dumps the heat. You can increase the eff of any IC by increasing the flow rate......with the provisio that the HE can dump the extra extracted heat.
100% distilled water + water wetter would be the ideal ticket...at least for > freezing. You don't require a 50-50 gycol-water mix in Florida. The better versions of water wetter will contain anti-corrosion inhibitors. You could also add anti corrosion inhibitor's to distilled water. You don't need to add gycol.... just for it's anti corrosion additives. Just buy the additives alone.
Jimbo
