I am currently using a KB 2.6L, KB reservoir, Afco dual pass heat exchanger with fans, and Bosch pump. I am rerouting my h/e plumbing to fill the h/e from the bottom, and possibly add another Bosch pump. I will also be adding my VMP GT500-look (3x stock volume) reservoir. In addition, I will be shrouding the 3/4" I.D. rubber lines with this product from DEI.
http://www.designengineering.com/ca...line-sleeving/heat-sheath-aluminized-sleeving
Due to the inlet location of the tank, I may reverse the flow of the system to make the routing cleaner and more efficient. Does anyone know if you can reverse the flow in a KB intercooler? I've been calling them all day but I keep getting a busy signal.
I am also considering using 2 Bosch pumps, and I'm not sure if it is best to have them close together, or if they should be located on opposite sides of the "loop" See diagrams below.
I appreciate any input about location of 2nd pump and routing plan in general.
Fig 1: Reverse flow, single pump
Fig 2: Reverse flow, dual pump option 1
Fig 3: Reverse flow, dual pumps, option 2
