How many miles is on this DS?
I wouldn't sweat it...stuff breaks. It is indeed disappointing that you got so few miles out of it, but send it to DSS and let them send you a new one (hopefully at no cost to you other than return shipping) and you should be up-and-running.
I have Skwerl's old T56 MAgnum XL DSS and it has worked flawlessly, so I suspect yours lacked lube, or had bad bearings, or who knows what. DSS certainly does not make the internals that you were showing in the video (bearings, etc.) - they simply design and weld the shaft but source the other parts (that failed) from elsewhere...so it may not be their fault other than being the seller of the completed assembly so they take the hit from the inferior 3rd party sourced giblets.
Let us know how it plays out. I wouldn't judge DSS until they have a chance to see this and respond.
Shane, the T56 came with a Dynotech driveshaft. I had a DSS with the stock 3650 transmission.
To be fair, Gabe was lowered and didn't check the pinion angle. That it lasted as long as it did means he was probably just barely in or out of spec.
Pinion angle, even only "slightly out of spec" should be a non-issue for a CV joint. DSS states as such on their own site...
Quote Originally Posted by DSS:
...with the CV in the rear there is no need to change pinion angle on lowered cars.
As Tob just mentioned on the svtp thread,
The grease, to my eye, just looks like it has been under heat for a while. They list the specs for a reason. I just think calling a product bad when it may not have been installed to spec is a bridge to far.
EDIT: I guess they say you don't have to check the angle, so you did install to spec. Just seen so many issues that I would never have installed without being checked.
I went with Shaftmasters for the reason I can change out the U-joints when I need to and they are grease able. They will probable have to cut the end off and weld in a new one. You might have them look at the other end while they have it.
Yeah I'm gonna have them check it out end-to-end, and re-balance it.
I'm also hoping that they'll be able to add some grease fittings
