05-09 Upgraded fuel hat 600hp
This setup will support around 600hp as it sits and 700hp with a bap. 05-09 GT hat modified to fit Walbro dcss 405lph pump and fuel system wire upgrade kit which runs 10 gauge wire with relay to the fpdm to support the bigger pump. The fuel hat is completely assembled and a direct swap drop in. $325 shipped obo.
Yes requires tuning. It will start and drive fine without a tune. But you will dump fuel coming off part throttle and be rich at wot as the pump flows over double stock.
Yes. Like stated oem fuel hat modified with the pump fully installed so its a direct drop in swap.
Black Bullitt
Chicago
Odd question, but how loud is this fuel pump? It's between this and GT500 pumps. Going for about 520 rwhp
Kylar
CT, USA
I have one, and i cant hear it at all. So i would say its as loud as a stock pump. Works great with my D.O.B setup.
Like mentioned it is very quite for such a big pump that flows over double the stock one. I would say it just a tad louder on priming at key on and no discernable difference when the car is running.
