AbdullaGT500
Currently working on a 2013 Boss 302 that we bought missing a few parts. I've installed everything(minus the cooling fan) back to stock including Boss 302 intake, stock air box, stock maf, stock injectors, etc. The problem I'm having is the car will rarely start. It will take 3-4 tries til it stumbles and runs for a few seconds, then it dies. If I feather the gas pedal once it is running it will struggle to stay running, but will. At about 3,000 RPM it will smooth out sometimes, other times it will just die again. If I do get it to smooth out, it will fall back and idle perfect for about 10 seconds, then will die again. Once it does run, there are no codes or lights. Also, the factory wideband gauge is pegged at 20+ when it does get running, also checked this with the SCT doing a datalog. It does seem like its choking out, as in not enough fuel.
Things I've tried:
-Different MAF
-Unplugged MAF
-Preloaded SCT tune for stock parts and 87 octane, reloaded several times
-unplugged evap
-Checked fuel for freshness, made sure it is actually getting fuel to rail
-New battery, plus a jump box
-Checked for vacuum leaks, couldn't find any
-Checked throttle body for proper movement
History on the car is it had a paxton on it at one point, which was removed before I got it. I'm not sure which tune is on the car, but I've tried an SCT preloaded tune and it runs the same on both tunes. Also has a Vortech Boost a pump, which I've removed(ran the same with and without it).
I'm lost. Only thing I can think of is bad PCM at this point. Any tips, suggestions or things to look for?
Things I've tried:
-Different MAF
-Unplugged MAF
-unplugged evap
