Boss 302 5.0 tough to start, very lean.
AbdullaGT500
Little Rock, AR
Currently working on a 2013 Boss 302 that we bought missing a few parts. I've installed everything(minus the cooling fan) back to stock including Boss 302 intake, stock air box, stock maf, stock injectors, etc. The problem I'm having is the car will rarely start. It will take 3-4 tries til it stumbles and runs for a few seconds, then it dies. If I feather the gas pedal once it is running it will struggle to stay running, but will. At about 3,000 RPM it will smooth out sometimes, other times it will just die again. If I do get it to smooth out, it will fall back and idle perfect for about 10 seconds, then will die again. Once it does run, there are no codes or lights. Also, the factory wideband gauge is pegged at 20+ when it does get running, also checked this with the SCT doing a datalog. It does seem like its choking out, as in not enough fuel.
Things I've tried:
-Different MAF
-Unplugged MAF
-Preloaded SCT tune for stock parts and 87 octane, reloaded several times
-unplugged evap
-Checked fuel for freshness, made sure it is actually getting fuel to rail
-New battery, plus a jump box
-Checked for vacuum leaks, couldn't find any
-Checked throttle body for proper movement
History on the car is it had a paxton on it at one point, which was removed before I got it. I'm not sure which tune is on the car, but I've tried an SCT preloaded tune and it runs the same on both tunes. Also has a Vortech Boost a pump, which I've removed(ran the same with and without it).
I'm lost. Only thing I can think of is bad PCM at this point. Any tips, suggestions or things to look for?
007GTCS
This is probably going to sound stupid, but fuel filter? Could have sat and clogged, and fuel pump could be bad. Sounds like not enough fuel. So I would start with those.
Gabe
Whippled Coyote
Fuel filter is not replaceable, it's part of the fuel pump on the Coyotes.
Any chance you have another bad crank sensor?
5lho
Unlikely it's a bad pcm if you can load tunes and communicate with it.
Have you verified the engine's mechanical condition? Comp check, leakdown?
How about going over it for vac leaks again, post maf? They are super hard to detect on this car because the computer is so good at working around things. If you datalog (when it runs) and see massive low rpm fuel trim correction, that's a bingo, as it were.....
AbdullaGT500
Little Rock, AR
I have not checked the crank sensor, it does attempt to crank and does start, just very rough when it does.
I have not done a compression or leak down test, but the way the engine dropped down and held idle for 10 seconds or so leads me to believe the engine is sound. It sounded perfect for those few seconds. I'll log it again and see what I can find.
cbass
m̶o̶u̶t̶h̶s̶e̶x̶
Rochester, NY
Are you using the stock o2 to read afr? I would try a standalone sensor. Also, have you checked what injectors are in it? Wouldn't surprised me to find a random mismatched set of injectors on a repo car that had parts stripped.
AbdullaGT500
Little Rock, AR
Yes using the stock o2 sensors. I bought a set of take off injectors from a member here. I really doubt injectors are the problem.
I managed to get it to stay cranked for about a minute today. I made a video of it which I will post tonight.
JEWC_Motorsports
S197 Junkie
Have you checked the fuel pressure yet? The bap could have fried the fuel pump.
AbdullaGT500
Little Rock, AR
I have not. What would be the best way to check fuel pressure? Trouble is getting it to stay running without someone mashing the gas. I did unhook the fuel line and turned it over, which it did keep a steady stream of fuel coming out.
AbdullaGT500
Little Rock, AR
Have you tried new o2's yet?
I have not. Forgot to mention, first attempt to start it today and the check engine light did stay on. Code was p1639- Vehicle ID Block Corrupted, Not Programmed. At this point I flashed it "back to stock" and the above video.
MechE
Southern CT
just some thoughts from a novice that maybe will spark an idea from someone who knows what the fuck they are talking about:
idle air control valve dirty?
Is there something going on with the exhaust tripping the knock sensors?
5lho
Where do you find these pieces of junk? It seems every car you come on here talking about is a three year old car needing a new engine, or bits and pieces put together or...this issue.
I'm still sticking with the massive vac leak, maybe in the manifold or flange itself, if there's nothing obvious in the piping, given it's showing spectacularly lean. A datalog would show this, if possible, because it would show heavy fuel correction at low rpm that tapers off. How much idle vac in the engine showing it's pulling? Should be close to 20" and steady.
I guess failed O2s are a possibility but they usually fail and default to full rich, not lean.
Strengthrehab
From what I gather by his posts--he finds these at auctions. Probably reposessions.
AbdullaGT500
Little Rock, AR
Find them at auction, fix them up(restore) and resell them. Buy them cheap, fix them up nice and put them back out there. I actually enjoy doing it, getting paid to do it is a plus.
I've looked inside and out for a leak, plus the entire manifold is brand new from ford racing with all new gaskets. I'll have to do a little more checking today.
Boaisy
Dark Knight
Memphis, TN
I think I know of what car it is, or at least I saw it online a few weeks ago. By the pictures I saw of the engine, it was stripped down to just the long block, no intake. I believe it was an auction unit. Looked a little rough.
EDIT: kinda tree'd.
deebo05
was the car flashed back to the as built stock boss file?
if not then its most likely the tune is still setup for the Paxton and will run lean. because of the maf.
loading the canned sct files just modifies whats on the ecm,It doesn't overwrite.
I would start with a as built file or get a custom tune
