So one thing I don't know crap about is figuring out the best gear ratios and tire sizes I should be sticking to. Thinking I'm going to be putting a magnum XL trans in here that has the option for 2.66 or 2.97. I currently have 3.55 gears in the rear end and 28.46 DIA tires.
Current Setup -
3.55 Rear End
28.46 DIA tires
Probably 20# boost from a supercharger setup (maybe going to go back to the ole TVS route)
So do I get the 2.66 or 2.97 first gear in the magnum?
Do I need different rear end gears?
I have a leaking seal in the rear end I have to fix and I plan on putting in a truetrack so doing gears isn't the worst thing in the world.
The focus would be on street drivability.
Current Setup -
3.55 Rear End
28.46 DIA tires
