302
I was at the track tonight. Did a quick 3rd to 4th gear shift at 7k+/- RPM and i was locked out of 4th gear. Seemingly the car over-reved. I tried putting it back into 4th because maybe i let out of the clutch too soon, or missed the gear? Cool no problem. Well i noticed when i tried to press the gas it was sluggish and did not want to go anywhere. Thought maybe i was too slow for fourth and back out and put it into second. No dice, same result. Looked at the instrument panel and i had the service engine crescent wrench present. The car seemed to be in some sort of "limp-mode" and would not rev or go in any gear at any RPM. Came to a stop, turned the car off. Waited a few seconds maybe a minute, cranked the car back up and it was normal. Goes into every gear like normal, shifts normal. Mechanically fine. Is this a safety lockout issue to ensure over-reving does not hurt the engine, or what? Comments welcomed. Ruined my track experience, came home to post about it after it happened to see if anyone has had any other issue of the sort
