Boosted05GT
Papa Smurf
Just installed after market racing seats and the factory plugs under the seat are no longer connected. There is no airbag or seat belt chime but the light gets annoying. Anyone fixed this issue yet?
its really hard to concentrate on your question with that pic in your sig.... lol
Put a piece of black electrical tape over the light.
There was a black box under the seat which i believe is what you guys are talking about. I will try to yank the box with all the other wires off and mount it under the new seat. The female side of the belt buckle is attached to all the wires thats mounted under the factory seat.
for vehicles not equipped with seat bags, there is a resistor ford
part# XF2Z-14B022-AA that works just like a shorting bar that you would plug into the connector that's there that I believe will fix your problem.
Will the steering wheel airbag work or does it just fix the dash light?
I disconnected those also (put Recaro’s in) and the yellow plugs eliminated all lights and chimes. I had side airbags though. Don’t know if that matters.As I previously stated, your light is on because you disconnected the driver's seat track position sensor and the passenger's seat occupancy clasification sensor. I'm not aware of any test connectors to bypass these sensors.
