Nuclear
Gentlemen, I'm looking for some experience... (couldn't find much using the "search" feature).
I'm planning a swap to some Brenspeed Detroit Rocker cams on my nearly stock '06 4.6/3V 5-speed. I'd like to perform the cam change myself, to save a little cash. Some cam-install instructions require the removal of some/all of the cam followers.
Recently I watched a video of a mechanic chaging cams WITHOUT removing any followers. He just gradually and evenly drew down on the cam cap bolts in a pattern starting in the center (similar to a head-torquing sequence). Now this seems like the way to change cams. No spring compressor needed. No time wasted messing with followers. The only special tool required would be the chain wedge tool.
Does anyone have any first hand experience (positive or negative) with this install method?
Any help is greatly appreciated.
Nick
Nick
