I'm reviving this because I've had a shifting issue and I've been unable to resolve it.
When I bought my '05 GT, it came with a Hurst shifter, which was a complete piece of cr@p! The bushings allowed for too much play and it was easy to miss shifts. I decided to put in a MGW just like I had in my '08 GT.
The shifting improved quite a bit after the MGW was installed, but I still have some issues. When the trans in in gear, any gear, there is 1" of side to side play on the shift lever. It still causes me to have problems getting the trans into gear, especially with higher RPM shifting. I noticed the side to side play in the shift linkage at the front of the shifter arm where it attaches to the part that goes inside the transmission. Today, I attempted to add some washers in there to get rid of the side to side play, but the side to side play still there. It seems that the bushing and parts inside the connection are worn. Does anyone make an aftermarket piece to replace the bushing and O rings in between the shifter arm and the part that sticks out of the transmission? I saw that some people removed the white bushing in the linkage at that point, but I don't see how adding more play in the linkage will resolve the shifting issue.
My '08 GT seemed to have absolutely no issues with the MGW shifter and 6500 RPM shifts. However it didn't have any noticeable side to side play in the shifter when in gear. I'd like the '05 to shift like the '08.
