Turbos not spooling?
Flapjack
Lunatic engine swapper
Colorado Springs, Colorado
Went to take the car to the dyno today. On the way there, I noticed it was only making about 3psi. I got to the shop and let the guys know I'd be a few minutes while I investigated.
Even in first, it only is making about 3.5 to 4psi. Springs are 7.5psi, and the EBC is set to a 50% duty cycle, which nets me 12psi.
I haven't driven the car in about 2 weeks. It seems to be running fine. No loose vacuum hoses, intake tubing, etc... I never actually hear the gates open.
The kit is a THP twin kit. Never had a problem making boost before today.
Sent from my Galaxy Nexus using Tapatalk 2
19COBRA93
Ford Racing
Clinton, Ut
How does it sound? Can you hear the turbos winding up? On one of my turbo '93's I had an intercooler weld split, it wasn't much of a gap, but I couldn't build more than about 3lbs. I could hear the turbo winding up, but no boost. We had to do a smoke test to actually find the leak it was so hidden.
I'm betting on a leak somewhere between the turbos and the intake manifold.
JeremyH
3V Fuel Guru
Virginia Beach
Sounds like a boost leak somewhere on the coldside, they can be very tricky.
Flapjack
If you can, check to see if your wastegate isn't partially stuck open.
How can you check it?
The turbos start to spool and have a good whistle to them, but it never sounds like the wastegates open. They're by far the loudest part of WOT, so I'd be able to tell if they're open. The guy at the shop says one or both may be partially stuck open, but both seems highly unlikely.
That's what I thought, as I've blown the intake tube off a few times, but I couldn't see anything out of place.
retfr8flyr
The Old One
Providence Forge, VA
Do you have a boost controller on the car? If so it could be the solenoid on the controller. I had the same thing happen with mine when I had a different controller on the car. It would make W/G spring pressure but that was as high as it would go because the solenoid wasn't working correctly. My W/G's did open though, so it's probably a leak in the cold side but it must be a large leak.
Earl
Flapjack
I vote cold side....
Starting to think that way, too. Simply because I should've heard at least one wastegate...
Earl
I do have a boost controller, but I'm not even making spring pressure. I did go through the EBC settings, just in case. I've kinda rule it out at this point, though. If it was stuck open, I'd see a lot of boost. If it was stuck closed, I'd see spring pressure... right?
retfr8flyr
The Old One
Yes it should, that's why I also think it has to be a cold side leak. I just don't see how it could be that big of a leak and you not already notice it.
Earl
Flapjack
Earl
Yeah, I don't either. It was fine last time I drove it.
It's at my old house. I'll get it home this weekend and up on jackstands...
michael.konor
Georgetown/Fort Hood, TX
If your wastegate wasn't opening, wouldn't you overboost? In any case, you could eliminate the boost controller if you reconnect the wastegate vac/pressure line directly from the turbos to the wastegate and then see what your boost level is.
If not there, I'd start tearing into the cold side.
BTW, how's the idle and un-boosted driveability? Changed?
Flapjack
Yes, but I don't think it's stuck closed. at this point, I don't think it's opening either. I'm not building enough pressure for it to open. They're either stuck open (don't think so, because I can't hear them at WOT), or there is something wrong on the cold side. This weekend will be the soonest I can work on the car. I'm suspecting either a clamp loose somewhere, or maybe the BOV stuck open.
I can try that. I think I would just remove the lines from the top of the WGs first, though. At that point, the EBC would not be controlling anything and I should be seeing spring pressure. I still don't think it's the EBC, because no matter what it is wrong with it (if installed right), I should always see at least spring pressure.
That's the plan for now. I'll get it up on jack stands, pull the bumper cover off, and inspect every single clamp in the system.
It drives great... like a dream. Idle is good, acceleration is smooth, I just don't have as much boost/power as I used to.
Flapjack
Figure it out. I found some time to get the car up on jackstands. Of course, it was one of the clamps I couldn't see with the car on the ground.
retfr8flyr
The Old One
Glad you found it, I had my connection at the TB blow off on the dyno at 20#. It had been fine until then.
Earl
