Surfstang2020
Wow those bbs are sick man
^Gorgeous.
How much of a spacer did you need? Also, do you need a spacer to fit your Rotiforms around the brembos?
It will definitely be a stretch to get this to work out (pun intended).
Looks good though. My mind goes to this when I see that wheel and the RTR splitter, although these are HRE's
That rendering looks perfect, the execution wasn't to my liking.
That looks badass.
Why doesn't anyone use fender flares?
if the car were cheaper, i'd consider it. once you drill and cut the fenders, there's no going back
Looks great. Do they still stick out when car is on the ground? I would like to see some pictures. And some pictures of rear wheels as well.
Arp studs an wheels look awesome! Overall how hard was the stud install?
phil we need more pics asap!
also, is using an impact hammer okay for the hubs when swapping out the studs? hammering it out would make it quick work, but everyone says it's a big no-no
Holy hell that looks good. Thanks for posting
Looks sweet. I picked up the same set except my fronts are 8.5s. Contemplating going with a square setup after seeing yours.
What color did you go with?
