Project Update for February 2, 2013: This thread update covers the first 2013 NASA Texas race weekend we attended in the red Vorshlag 2011 Mustang GT. This January event is always held down south of Houston, but is sometimes plagued by poor weather (rain or cold). I was going to skip this event, but peer pressure worked and pushed both me and Amy to attend. I'm glad we did - the weather turned out to be extremely nice and we had a total BLAST running the red 2011 GT in the new TT3 class.
I will back up a bit and talk in more detail about the classing tweaks that NASA made for 2013, which I hinted at in an earlier post in this thread. This is the first significant classing change that I have noticed in TT since we started running this series in 2008. It looks bigger than it really is, as most of the changes were mostly to the class letters/nomenclature, but there were some substantial changes to TTA (now TT3).
2013 NASA TT Class Updates - Letter vs Number Classes
None of what is written below is official or approved by NASA, just
our overview and interpretation of their rules. Don't take our word for it -
read the rules yourself if you want to learn how to class your car for NASA TT. These rules only span 54 pages and only parts of that will even apply to a given entry. If you get mired up in the classing though, don't worry -
we're here to help. Matt and I at Vorshlag have helped class hundreds of new folks into NASA TT. We have our own "class configurator" that is normally more up-to-date than the one's NASA makes. Shoot us an e-mail and we can help get your car classed, free of charge: info (at) vorshlag (dot) com, with a subject of "Help with NASA TT Classing". We can help with SCCA Solo classing as well, but that might involve substantially more tortured logic.
2013 NASA Time Trial Rules: http://www.nasaproracing.com/rules/time_trial_rules.pdf
NASA classes each Time Trial car into a "base class" and gives it a "base race weight with driver". Each base class has a "base tire width". Some cars have handicap points in their base class, denoted by one or two "stars". One star = +7 penalty points and two stars = +14 penalty points. Then modifications each cost "points", and you get 19 points to play with before you bump up a class. Running below your base race weight costs points (but heavier gains you points back). Running more tire width than your base size costs you points (but narrower gains you points back). The points for parts eats up most of your allotment, but whatever you change you can never violate the power-to-weight limit for a class. It sounds confusing, and it kind of is... but only because it is so unconventional. But this type of classing is also liberating, fun to explore, and competitors can "bench race" set-ups with different mods to play with their 19 points in class. Or you can go buck-wild and use more than 19 points and bump up a class... then you get a total of 39 points (or more) to play with. Make sense? You can keep adding mods or lowering weight or adding power to keep your car at the competitive limit for each up-class jump you make. This is how the new "letter" classes work (TT
B-TT
F)
Vorshlag built entries for NASA TTD and TTA classes.
Our Intro to NASA Time Trial article, circa 2008: http://www.vorshlag.com/tech_timetrials.php
This means you can have a Miata with wild aero, sticky Hoosiers, and a supercharger racing against a nearly stock E46 M3. And oddly enough, it works, as there is always the power-to-weight element... measured horsepower and measured weight reign everyone in. There are not "categories" to jump up, and anything can eventually be classed with almost anything else, if a given car gets modified radically enough.
In 2012, beyond TTA were the top three classes which were always strictly power to weight based, with no more points to play with. I now call these the "number classes", but in 2012 they were TTS, TTU, and TTR. There are "modifiers" you can exploit, to get you a little more power or a little less weight, if you have say... a 4 door vs a 2 door, or use a 275mm or narrower tire, etc. Otherwise it is strictly power to weight based. When we first started racing our 2011 Mustang in TT (see above), it was in TTB, but since it came with the Brembo brakes (+2), no decklid spoiler (+4), and the CS front lip (+3), we had very few points left to use. If we had added R compound tires and any exhaust mods the car would be easily into TTA and then even into TTS on points alone, due to the SCCA class allowances and rules we were focusing on (STX then ESP). We ran a few TT events with our STX set-up and it was difficult to manage the the narrow-ish street tires (just like it was in autocross!), but our ESP set-up with 315mm Hoosiers or Kuhmo race tires worked pretty well, but bumped us clear up into TTS. We almost won the November ECR TTS class, until a TTU car bumped down their power and ran quicker and beat us. Oh well, we were still too heavy and/or underpowered for TTS, nowhere near the power to weight limit. It was what it was... we were building our car around SCCA rules and letting the TT classing fall where it may. Other than adding the transponder, a brake pad and rear aero change, our Mustang was still set-up around ESP autocross rules for most of the 2012, even when run at NASA events.
Let's look at the old vs new classes in NASA TT, of which there are still 9 classes total. Nine classes, not 427 classes, like in SCCA Solo. Just sayin'. Anyway, most classes had little to no change other than a more clear naming style (numbered classes are power to weight only, letter classes are still points based). Here are the changes from 2012 to 2013, mostly affecting just one class...
NASA TT Classing - Name and Ratio Changes
2012 ... 2013
TTR -> TTU (Unlimited Wt/Hp)
TTU -> TT1 (5.50:1 Wt/Hp)
TTS -> TT2 (Was 8.70:1 Wt/Hp but went to 8.00:1 Wt/Hp)
TTA -> TT3 (Was 8.70:1 Wt/Hp but went to 9.00:1 Wt/Hp) For TT3 only, non-OEM Aero is a 0.5 modifier (in effect requiring 9.50:1 Wt/Hp).
TTB - 10.25:1 Wt/Hp
TTC - 12.00:1 Wt/Hp
TTD - 14.25:1 Wt/Hp
TTE - 16.50:1 Wt/Hp
TTF - 19.50:1 Wt/Hp
As you can see, before there was some overlap with TTS and TTA both having the same 8.7:1 power to weight ratio. But TTA - TTF were still all "points" based as well as power to weight, whereas TTS was
only power to weight. Modifications in TTS were relatively unlimited, with those modifiers for certain limitations. So in reality TTS and TTA had very similar on-track performance. Now with the new TT2 and TT3 ratios and the removal of points based modifiers, they have effectively made the difference between TT2 and TT3 more significant and it creates more places to run your car, and more time difference between the two classes.
In order to keep it interesting in TT3, they also let you choose between a 9:1 and a 9.5:1 ratio. If you keep "stock aerodynamics" you can go with the more attractive 9:1 ratio, but if you want wings, splitters or other aero changes you get the 9.5:1. Still lots of room to tweak and play ... and bench race. And since we are in TT3 now, we get to strategize and play with more aero vs more power. Kind of looking forward to testing this.
As you saw in my last "mini-post", we went with TT3 and we chose the 9.5:1 ratio with alternate aero. Hard to give up the big rear wing and front splitter after you've tried it. We had to add a few pounds, but with our most recent dyno of 424 whp, and the +.6 modifier for running over 3750 pounds with driver, we were able to get a race weight of 3775 lbs, with driver. Here's the math.
3775 lbs / 424 whp = 8.903 pounds per hp... +.6 modifier (for running over 3750 lbs) = 9.503:1
So we were ready for TT3 and maxed out on the power-to-weight. How would we fare at MSR-Houston? Honestly, I didn't have high hopes. We would be running heavier than ever, and I don't know that track well. I've driven it twice before, but once was in the rain on street tires at stock power levels and the second time was last year at TX2K12, where we had massive tire problems (some used Hoosiers I brought kept popping internal cords and coming apart) and still nowhere near the preparation level the car had in mid-2012 to now. There were nine people signed up in TT3, the biggest TT class so far, and I was hoping to crack the top three if I put in a good run. The old TTA track record for MSR-H CW was a 1:44.3, but I couldn't remember what we ran there before going this direction. The tires we were taking were dead though, so I was very unsure of the performance potential. We were also going to share the car, with me driving one day and Amy the next, so we would only get about four sessions each. Time would tell...
NASA @ MSR-Houston, January 19-20th, 2013
NASA ran MSR-Houston's 2.38 mile course Clockwise this race weekend.
After making some new number and sponsor/product graphics for the 2011 Mustang GT, we loaded up the trailer and Brandon (Vorshlag's uber-photographer), Amy, and I left Dallas on Friday afternoon and towed 5 hours to the south end of Houston. We arrived at the track late, unhooked the trailer in the pitch dark, and headed to the hotel a solid 20 miles away.
Sunday, Race Day One
Next morning we got in before dawn, unloaded the Mustang and went to tech to get our 2013 Annual Tech sticker and renew our logbook ($10 for the year). We had NASA decals to apply, two transponders to mount and test, and a hundred other things. It was quite chilly, with temps in the low 40s, but the weather outlook was warming for the afternoon and predicted to be warmer still on Sunday.
Vorshlag photo gallery: http://vorshlag.smugmug.com/Racing-Events/NASA-MSR-Houston-011913/
The guys from
Evo-Dynamics brought four EVOs and a GTR down from Dallas and hung out with us at the Vorshlag trailer all weekend (see our "foggy paddock" above). We had shade, lots of chairs, and lots to drink. Lots of fun was had with these guys all weekend, both on track and off. That's half the fun of a NASA race weekend - hanging out with fellow competitors and friends between race sessions, shooting the bull, bench racing, talking a little smack, and having fun.
The morning was pretty hectic for me, as I was both competing in Time Trial as well as instructing, which meant I had to go to three meetings that morning: instructors (missed it!), Time Trial and HPDE, to meet my students. I had an HPDE2 student driving in a beautiful and well prepped Porsche Cayman S. I rode along with her for three sessions then picked up a 2nd student later that day and Sunday.
I was so rushed that morning that
I forgot to turn on my transponder in my first TT session, which meant I got no time. Normally that's not a big deal, as the first TT session on Saturday in NASA Texas doesn't count for competition, just for gridding. So this meant I was at the
back of the grid, mired in slower traffic, for all of TT session two. Never got even a remotely a clear lap, but was quick enough to move up to grid position 10 out of 44, based on those session two times. Then in TT session three I was quickest of the group, which was mainly because the TT1 guys sat out, which moved me up to P2 in TT session four. So surely now I could get a clean lap or two without traffic...
Click above to watch in-car video of two laps in TT session four, in 1080P.
So TT session four wound up being perfect for getting fast laps, eventually. After chasing John Gross' TT1 C6 Z06 for part of the first lap, I watched him take the "agricultural line" into the Diamond's Edge corner, while I was giving Josh's TT2 car a point-by. Diamond's Edge is a tricky, fast corner where I enter in 5th gear, tap the brakes at the brake markers, turn in, let the car corner hard, then get back on the gas and brake for the tight 2nd gear corner at the end of the sequence. Then you touch three curbs through a wiggle at the end and accelerate back down another long straight. There is a lot of time to be made or lost into the braking zone in this corner sequence and John just got a little overzealous. He wasn't the only one using more than the track allowed that weekend, but luckily I didn't add my name to that list.
Saturday Results: http://www.nasatx.com/resultspoints/2013Results/MSRH_Jan_19_Saturday_TT.pdf
Old track records for MSR-H (CW is slower than CCW):
http://www.nasa-tt.com/Texas_Track_Records/p2046_articleid/11
Of course, there was no contact or crashes of any kind in any TT session (there never is), and the only real carnage was John's ZR1 splitter (now a "6 piece unit") and a couple EVO motors were served up to the Gods of Boost. Some dirt and grass was killed, but nothing bad. There were a lot of E46 M3s in TTB (and one that got bumped to TT3), with KenO leading the pack once again, but winning by a mere tenth of a second over Allan Page. Three of these M3 racers all run the same AST 4200/Vorshlag camber plate set-up and a 4th entrant has our plates - and he wants shocks. All of these M3's are driven to the track and are still street cars. Very cool.
So my fourth session went well and I got a couple of clean laps, finally. After chasing Josh for two laps, I busted off a 1:42.1 and 1:41.5 laps, then caught the back of the field and came in after four laps. The tires were DONE and I didn't want to risk a spin and get a DSQ for the session. So when I came off track I was told to head to the tech shed for a weighing. No problem, I should be fine. Errr... the fuel level was lower than I had planned and I missed weight. Damn! That DSQ'd the session, but my times from previous sessions (1:42.0) were still fast enough for a class win, still with a nice margin and new track record. We went and re-weighed a few times that afternoon and added enough extra ballast in the car to be legal for Amy on Sunday. We overshot by 50 extra pounds, "just in case".
Josh Dunn was fast in his EVO running in TT2, and he and I swapped best times with each other all day on Saturday, with Josh's TT2 drive edging me out by tenths at the end of the first day (and he went faster still on Sunday). At the end of the day's racing, there was a great banquet by the NASA folks and everyone stuck around to eat, drink, and hang out. There were trophies presented to last year's regional class champions, based on points earned over the 2012 season. Then we hit the hotel and crashed.
(continued below)
