07gtcs
So multiple sensors and enough of my wasted time have brought me to the conclusion that there is a problem with the wiring for both of my upstream sensors. Bank 2 worse then 1 but neither are working properly,
I've tried Boch and OEM and both sides are sticking to the lean side. Well bank 2 rarely puts out any voltage at all now.
I'm considering pulling the wiring right out of the harness for the upstream all the way to the pins in the connector for the pcm and just moving the downstream to the upstream location. That way I wont be stuck using extensions on the OEMs or the Boch's with the longer pigtails to get rid of the extensions. Theres not enough slack in the harness to reach the Pacesetter Lt's.
I cant think of a single reason why this is a bad idea. I dont use the downstream anyways and if I had to rewire a portion of the harness I would want it to be on the downstream anyways if I ever need to turn them on again.
