Ok..Now I am Excited !!
GT E UPP
Toronto, Ontario, Canada
Well, seems Spring is finally here..!! All my parts have been delivered (see list) and now all the fun stuff begins at the Steeda Shop for my Build.
Looking forward to some Good Wheel HP...!!
-Brenspeed B326 (5.3L) Stroker (9.8 CR)
-FRPP Motor Mount Kit
-FRPP Head Gasket Kit
-FRPP Head Studs
-FRPP CNC Ported Heads
-FRPP Lash Adjusters & Followers
-Steeda High Output Coil Packs
-Brisk Silver Racing Plugs-12MM
-Spec Super Twin Disk Clutch/8 Bolt Aluminum Flywheel
-High Volume Clutch Line Kit
-Mososo 7 Quart Oil Pan
-Stewart Water Pump
-GT500 High Pressure Oil Pump
-PA Performance 130 Amp Alternator
-Injector Dynamics #69 Fuel Injectors
-Fore Innovations Fuel Rails and Cross Over kit
-FRPP Cam Chain/Sproket Set
-Smaller Whipple Pulley
And finally,... FRPP XBrace with Carpeted Rear Seat Delete Panels
:cheers:
nice project! good luck
Mike K
WANNA BE FAST
Richfield, MN
Hell of a way to spend 15k good thing you didn't have to overnight the parts from japan.
Well, Spring is finally here..!! All parts have been delivered (See List Below) and now all the fun stuff begins at the shop on my Build. Looking forward to some Good Wheel HP...!!
-Stewart Water Pump
-Smaller Whipple Boost Pulley
:cheers:
Pictures please! Nice parts list.
^^^^^What he said.
LTHLCHRG
Toronto,Canada
-Stewart Water Pump
:cheers:
Saw your motor today Frank.looks good!they where talking about installing in this morning.
How long did you run the car at 11 lbs on the stock block? And did you do any drag racing with that setup?
I'm envious of the motor build, but I'm probably a year away unless something falls in my lap. Spending all my mod money this year on the new T56 trans and a TVS blower upgrade. I'm planning on limiting the boost at about 10 lbs until I can afford a forged motor.
GT E UPP
Hi skwerl, it's my summer daily driver and I've been at 11PSI (538 WHP) with stock bottom end for about 4 1/2 years now without any issues. Hasn't seen the strip (too many things break), just some very spirited runs from time to time when necessary, if you know what I mean (lol). So, I certainly didn't baby it, but on the other hand, i didn't beat on it constantly either. Have fun Man with your new T56 and TVS Blower upgrade. Keep Dream'n....:thumb2:
