This is for those who have blown their motors. I'm wondering about a few things and if it's not too painful I'd like to know what happened.
1. Forced induction or na? If forced induction what type and how much boost?
2. Pump gasoline, E85, or other?
3. Stock block or built?
4. Compression ratio or piston dish?
5. Spark advance and a/f?
6. WOT, normal driving, or somewhere inbetween?
7. What component failed?
8. Cats or cat free? If cats were they stock or aftermarket?
9. If it was a spun bearing what were the motor clearances and what oil was used?
Please add any other info you think applies or is needed. I just switched my motor back to gasoline. It's wastegated at 14psi with my 10.76:1 pistons and 15 degrees of spark advance at wot. I've thought of going to 10-12psi but it might stay at 14. FWIW an online boost compression calculator says that my boost/compression ratio combo is about the same as 17psi on stock compression. Gas is 92 octane.
