26 vs 28s
09gt3v
St. Louis Missouri
I kno I may sound dumb asking this and everyone will say use a calculater but I have a 28inch tall nitto drag radial on my 18s that I daily drive I also have a 26 inch tall slick on my race stars for the track and have 410 gears making 348 rwhp I'm curious if 26s pick the car up a lot like it seems in my calculations like it would
26" tire is the way to go for you, not a big pick up, but it will help. Better gearing for a n/a set up.
What does it run now?
09gt3v
St. Louis Missouri
It's gone a 12.2 on the 26" slicks at the track but on the street I always run my drag radial which are pretty close to 28 inch tall tire and I was curious of the difference between the two because I run dead even with a few people on the 28" drag radials
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Run the 28 at the track and see the difference?
I'm also curious on 26 vs 28 using slicks and 373's with over 700 to the wheels, through a a 4r70w auto. With 26" tires, I'm trapping at 6000-6200 rpms in the 1/4. I am wondering how things would change with 28" slicks.
At the track, what is your rpm when crossing the trap with the 26" tires? As long as you're not bouncing off the redline then I would keep using that size. If you increase power and run out of throttle before the end of the run, then you can bump up the tire size in order to effectively reduce your gearing slightly and allow you a few more mph before hitting redline.
But if you don't have the power to pull it, increasing tire size will probably slow you down.
TexasBlownV8
Central Texas
...that's what I'm thinking applies to my question as well... a 26" tire with 373's is closer to 390's, and as long as I have room on the rpms, should probably keep the 26's.
TexasKyle
D.I.L.L.I.G.A.F
Katy, Tx
Keep the 26" IMO. As you said, going to the taller tire will drop your final RPM. Not by much, a few hundred probably but you are already well below your redline. Going from 3.31s to 3.73s on the same 28" tire only netted me about 250rpm at the finish line, if I remember correctly (may have been a bit more, but not much) So..going the other way for you by going to a bigger tire would drop your RPM a few hundred.
09gt3v
St. Louis Missouri
Thanks guys and I have tried the drag radials at the track and can't get them to hook ever so it is just hard to tell!
TexasBlownV8
Central Texas
I hear ya! I have the same problem: dr's wont hook at the track at all...nor on the street from a dead stop. Spin spin spin, lol. hence the need to use slicks at the track, and where I want maximum traction and less chance of loosing control under heavy acceleration.
09gt3v
St. Louis Missouri
I second that I hate drag radials esspecially nittos
11secLX
Try a better drag radial like a M&H Racemaster in 28" or an ET Street radial but until you run out of rpm why bother to change size.
