I talked to a fellow with a 2012 GT. He switched from 5W-20 to 5W-50.... and his idle + wot oil pressure went way up. Also got a note back from some rep at RP..and he sez if your are not intending to track your car, don't use 5W-50. 5W-50 is a lot thicker..and has a harder time flowing through the various orfices, crank shaft journals etc. Since it can't flow as well, it all backs up...and higher pressures result. Nascar uses 5W-20... but they are after max power..and use oil coolers.
Some drag racers use 0W-5... for the same reason, max power.
Using 5W-50 during winter months...or where temps hover between 30-40F, might not be a good idea. But no big deal to use 5W-20 during the winter, 5W-30 for summer use, and no track service. If you want to track it some weekend, ok, swap in some 5W-50..and go for it. Oil is "cheap", just use what's optimum for either the application ....or the WX.
Jimbo
