@Pentalab
My GT with track package oil pressure is higher than the standard GT. My car idles at 30 psi and at 2000 rpm is 80 psi, WOT 100 psi (gauge only goes to 100 psi). I asked the service dept. and they said it was because it's the track package. Not much of a real reason and I didn't dig deeper. Although, I have searched the internet to no avail on the higher oil pressure for track package GT, I have found that the 302s run with higher oil pressures similar to my GT.
Also, there are a lot of parts you can purchase for the coyote engine that are on the Boss engine, e.g.. heads, cams, oil cooler, pistons, and the list goes on. Just a thought would be that since the track package GT designed use is for the track they made them similar to how the 302 engines would run and thats why they added the oil cooler and the Boss radiator. However, this is all just speculation on my part. I used 5w-50 for my oil and change the oil after 4 track days.
Also, the oil cooler using the engine coolant is not that big of a deal. My engine runs at 200 degrees F at the track and 190 degrees F on the street. I had thought of getting the FFRP BOSS 302 EXTREME DUTY OIL COOLER KIT -- M-6642-MBA. However, I don't think I need it.
