Just wanted to share my mustang
o2sys
Ebay, the only issue is now the tread pitch doesnt allow the shift knob to finish correctly so the shift pattern design/logo is not centered.
speedfreak1000
2 sided tape expert
Springfield KY
can you use a small black jam nut? or the smallest nut you can find that's threaded the same and paint it black?
I have a jam nut on my shifter and when I swap shifter balls sometimes I have to adjust it.
o2sys
Thanks. I emailed the guy to see what he says as well. Sharp ride by the way!!
Do you have the original keys? You need two of them in order to program the transponder chip yourself.
Sent from my HTC One using Tapatalk
o2sys
Badass car! Keep us updated on what else you do.
Thanks man! Especially from a former Saleen owner!
I'm thinking of putting the chevrons as the car feels naked without...
Also Saleen did give me free banner decal with the purchase of the kit lol
Yeah I was thinking that but couldn't find the correct size. I'm also looking for the same knob design but those that you hold down by screwing the small allen head screw at the bottom.
scramblr
New Braunfels, Texas
I do, it's just the site states 2010+ Mustangs, so just want to be sure. So you just had a guy cut the key and used the two originals to program the new chip? What about the FOB, how does that get programmed to the car?
scramblr
The guy just answered me about the key and said it does work on a 2006. Guess I'll give it a shot.
lethe
V4g!n@ #er
Everett, Wa
I only have 1 original key so i'm assuming i'll have to have the dealer program the new keys?
o2sys
Yup, two original keys are needed. So the options are
A. Go to the dealer and get it programmed.
B. Go to home depot, purchase a new key and have it programmed then use the original key, new key from Home Depot to program your new ebay key.
o2sys
No, not the fob. Well not sure about your Home Depot, but mine, they sell oem spec (meaning not original but close to it) blank keys for Ford, GM, and etc. And they can program the key for your using your original key. This way you will now have two programmed keys. Now you can program the the third one (the ebay key) in your car yourself following the instructions I posted.
Why not just ask HD to program your ebay key? Well they wouldn't do it for me, as its not in there system, they don't want to be liable, their policies this and that.
But to save all the headache and hassle, I would just go to the Ford Dealer and ask them.
scramblr
Key/Fob works flawlessly...thanks for the link. Went to Lowe's and they cut it for free, came home programmed it and good to go. Attached are the instructions I used. Remember, you have to program "ALL" your FOBs, not just the new one.
  • Key fob.txt
o2sys
Did the fuel filter/hose upgrade today:
Left the oem hard lines, was too lazy to remove it.
posted via Tapatalk
o2sys
Installed American muscle's radiator extension covers. The color and texture is completely off though.
Also put GT500 fuel rails and cleaned up the pcv routing a bit.
Before:
After:
posted via Tapatalk
Shotokan1509
CT
posted via Tapatalk
Yep, it annoys me and they don't fit that well either.. but still better for me than the headlight clip I had to fix
