1.2g with a Pilot Super Sport? Please excuse my skepticism
Same, then they told me they had a 285 square setup on the car, which all put it together.
God knows Jack Hidley would hand me my ass in any type of suspension discussion.
Isn't he on cornercarvers? Maybe inquire there?
Still extremely impressive. I will lay out my case for suspicion. Reference http://www.motortrend.com/roadtests/coupes/1107_2012_chevrolet_corvette_z06_centennial_edition_test/
A Vette with magnetic dampers and tires that are in a different(stickier) category altogether. 285's on the front and 335 rears. Of course with the fronts the lateral G will be affected by the weakest link in the tires (285). But that car *only* achieved a 1.13G.
Given that the vette weighs less, has a better suspension and "perfect" dampers, even with the reserve of the 285 width fronts, the vette is still on a substantially stickier tire.
So....that's all I'm saying. This is also why I started asking people on here in another thread (probably should have made another thread) about what kind of lateral G numbers they were getting and what kind of tires they had.
MM isn't a vendor hear and can't comment, which is unfortunate as I have a lot of respect for them and their capabilities and their long-standing accomplishments to road racing and mustang suspension development. I don't want to bash them without their ability to respond. God knows Jack Hidley would hand me my ass in any type of suspension discussion.
There are waaaay too many factors here to really, I mean REALLY, compare lateral G numbers from one comparison to another. Even if it's on the same track, there are just too many variables in the temperature, surface cleanliness, surface type, surface construction, humidity, driver confidence, etc, etc.
I pulled a peak 1.28 and was consistently over 1.15 G on 245/45/18 Star Specs with -1.7º of camber, Steeda Sports and Tokico D-Specs in a car that was very, very pushy. Who knows what I was pulling on 265/40/18 Hankook RS3's (by all accounts a faster tire) with 440/200lbs/in springs and -3.0º of camber.
All of those measurements were taken on the Lincoln Air Park's concrete which is a fairly abrasive and grippy surface. It was also well rubbered in and relatively clean on line.
I'm sure I could find a piece of Asphalt where my car would pull around 1.1g peak and a little over 1g consistently.
I don't understand, where in MMs page does it say that they averaged 1.2g on a skidpad run?
http://www.maximummotorsports.com/2011-2014-Mustang-Road-and-Track-Grip-Box-P1443.aspx
They say, "Delivers continuous cornering forces above 1.2g, as tested with Michelin Pilot Super Sport tires (tread wear rating of 300)."
Last I knew, C-C.com membership wasn't something that occurred by return email where you click the link to complete the process like it works at most other places. If you choose to join, plan on being patient and using the interim to find your thick skin . . .
I'm on a trip currently, so I don't have access to the original data logs that were taken for the measurements in question.
The measurements were taken at Buttonwillow Raceway Park, in configuration 13 I believe. I'm fairly certain that we did not use any data from the banked corners as these would obviously skew the results unfairly.
The data was measured with a Motec ADL3 data logger which is squared to the car before testing and has had all of the accelerometers temperature compensated.
We used the term "Delivers continuous cornering forces" to differentiate the measurements from some type of peak measurement, which would be nearly meaningless. Any time a signal is measured, that has any significant amount of time variance, the average level is going to measure very differently depending on the amount of integration (filtering) that is used. When I get home next week, I can post what integration time we used for the 1.2g measurement.
Yes, the tires were a square 285 setup. BW is paved with asphalt.
Jack Hidley
Maximum Motorsports Tech Support
Jack Hidley
The Corvette test that you referenced above pulled 1.13g on a skidpad with a presumably stock alignment. On a racetrack, I expect that its cornering forces would be higher than this. Skidpads almost always result in the lowest cornering grip measurements for a couple of reasons. I also expect the Corvette to have a semi performance alignment. This will reduce its cornering grip some also, compared to a real performance alignment
Jack Hidley
Maximum Motorsports Tech Support.
Indeed. You'll find that Jack is the "real deal" and loses more knowledge about suspension design, theory and operation over breakfast than most of us well ever have...All valid points as well.
Ivan, what is your sway bar setup? You got the stockers still? You take off the rear bar? How is the oversteer/under steer bias? You hit your bump stops any? Lets bring this thread back around to the topic.
My rear springs are very stiff (325lbs). I'm thinking about removing the rear sways to soften the rear for less "oversteer".
