Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
Positive displacement supercharged rear wheel drive mustang approaching 600 RWHP, probably close to WOT and wet roads= a bad decision.
Gabe
Whippled Coyote
Fun, but why "bad decision"?
Because i could've spun out and crashed?
Or unsafe to the engine?
WJBertrand
Installed a JLT axle expansion tank today. Found that the OEM breather was installed only finger tight but was also plugged. Heard a fair amount of air escape when I unscrewed it. This pressure inside the axle cannot be good for the seals. Took a lot of time flushing out the breather with brake cleaner and compressed air before installing it onto the expansion tank.
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
ordered some of these :eyebrows:
These will be feeding this
RideThePony14
NJ
Gave my car an oil change, changed the fuel filter, gave it a quick wash then finally mounted my new wheels and tires
mitch
HPDE Instructor
Ft. Lauderdale
Installed Russell SS Brake lines, Brake Cooling, Flushed brake fluid and filled with Motul 600.
Getting the new girl ready for some Open Track duty!
twilson1918
Bought a CFM oil fill breather, anyone know if there is a clip inside valve cover on the stock oil fill neck or just the tab on the outside?
GoneFord
Yorktown VA
Finally installed this...
Would have been easy but the J&M camber plate's larger bolts required some light dremel work. All is well now. Just a little contact with the silicone boot. I'll get it relieved when I have it powdercoated red to match all the BMR suspension stuff.
blk12gt
San Antonio
Very nice, but those reservoirs look hidious :p, would be nice to see you do something with that air intake...
Sent from my phone, spelling mistakes brought to you courtesy of tapatalk.
