2013Boss302
- Joined
- Mar 27, 2011
- Posts
- 72
- Reaction score
- 0
I live in Southern California
Mike Rousch at Mid Atlantic; no issues with the MAF here. Rev Auto is the only 5" intake on the market, all the other ones may have started at 5" but neck down along the way.
Not sure why you say it is overkill, it is the same price as the twin blade and moves a lot more air.
Do you have any data to back up your claim that the Rev Auto causes issues? Granted, it is SVTP but they are very popular on there and have not read of issues with them.
Concur about the price and length of wait time from Rev Auto; just wondering if you are somewhat "jaded" on the Rev Auto piece based on the price difference?
Shaun and Mike tune/talk together so I trust Mike to know what he is doing; the discusson about metal vs plastic for CAI's have been going forever and it seems there is data to support both pro's/cons.
My car did 8 runs in 88-90 heat with 1860 DA Monday at MIR with the hood open/cool downs between runs and I did not see any issues; granted, I was not data logging each run, Mike had it set up to data log on one pass but I think that was to adjust the rev limiter/1-2 shift.
Not "jaded" at all man. I've discussed this with several people that have changed intakes from the Rev Auto due to retaining high heat and having to have a little bit of extra tweaking to make the intake work perfectly.
The price is not really an issue with me man. It is expensive, but, it is also a heavy piece to boot.
In between cool downs is one thing. In your opinion, do you think the car would run the same if you went back to back with the intake getting hotter and hotter?
What mods did you have on the car when you were running 8's?
Again, I WANT a Rev Auto Intake, just wish it was made in aluminum (Weight is also a factor as Brad said it was about 25LBS without the filter, which could be a high number) and if it would have been made within the 3 week lead time they quoted me. I am all about the looks, but, I did want something that would perform since I did need it right then and there and the Rev Auto intake just wouldn't get to me in time since I had planned the tune session nearly a month in advance.
The discussion about running back to back is not valid as no car does well with back to back runs...
I will weigh the intake when I remove it this weekend, I don't think it is 25 lbs but I have been wrong before! If it is that heavy then you certainly have a point with the weight savings of the Airraid/FRPP CAI.
Wish I was in the 8's, LOL!
The restriction on these motors is on the exhaust side, not the intake. In my 5 months of testing the CJ intake with various throttle bodies and intake tubes, it resulted in 0 gains over the Boss intake and stock throttle body.
IMO the 5" intake tube does nothing over the FRPP CAI.
Do you have proof of this theory?
It's his opinion, based on the comparisons he has personally done.
there is a lot of retained heat since it is mild steel and not aluminum. My intake is cool within 5 minutes of popping the hood even after being driven on a 90 degree day.
his opinion was that the intake tube made no differance.
He said the the Manifold and intake made 0 gains over the CJ manifold and intake.
Well when he says 0 gains he's referring to track results which he tried for a number of months in his testing. Not dyno numbers. Brett could care less about dyno numbers.all I asked was if he had some sort of proof for his theory.
tons of people have done these mods and gained noticeable power.
So for him to say he noticed ZERO gains i'm just curious.
I don't see anything wrong with my question.
Thank you for clearing that up.
When he said Gains I thought he meant power numbers.
