Department Of Boost
Alpha Geek
- Joined
- May 26, 2010
- Posts
- 8,809
- Reaction score
- 29
There is the pump gas issue. I was referring to my experiences with a 2.3 Whipple that made 553 on pump at 17psi and 599 on E85 at 15psi. Due to the inlet it didn't make much more power past 15-16psi.
My experiences with centris are that they make hp easier. They don't have the instant torque or even as much torque but hp is fairly easy.
A Paxton 1200 at 10psi made 570rwhp on E85 iirc. Same setup on 92 pump was 526.
My D1 was real easy to make power with. 699rwhp at 19psi with E85. All of these numbers are through the stock cats.
The faster you spin a centri the more it makes. A pd makes peak boost early and stays relatively steady throughout the pull. As you know this is why we like the pd on the street, instant torque.
Those have been my experiences. Not apples to apples though, different motors of stock displacement. It does mirror what I see at dyno days. The big power motors are running a centri or turbo.
I've said it before and it's still true. The internet jades us and changes what we think is acceptable. I really like having a street car that makes right at 550 or so. It's pretty hard to use any more than that and it takes some of the fun out of it due to the increased concentration required when driving.
I can see where a centri could make a little more top end charge. I'm not willing to trade that for the torque though. At least on a street car.
And yes, the internet does fuzzy things up. I don't know who is lying. The people with the cars or the dyno operators, or both. Or if everyone is just lying to themselves. Or if in real life their IAT's are always killing power. I can't tell you how many "over 1000hp cars" I have run and beat with only 775hp (pump tune). Either I have the worlds fastest 775hp car or everyone else has the slowest "over 1000hp" cars.
And you're right, at about 550 things start getting silly. 650 is getting into "you had better know what you're doing". At 750 it is just plain stupid. My 2007 is still spinning the tires at 100mph and it has some serious rubber/suspension under it. If I hadn't spent 10yrs racing stuff with 200hp that weighed 375lb I would be more than happy.
