So...some progress on "partial retard." Not going full retard until 2016...maybe the car should be called "not-so-simple Jack."
How the car sits now:
With a 1/2 tank is weighs in just shy of 3500#.
Anyway...some stuff I have now.
Got the Watt's on- (not my picture or car, but pictures are fun.) From doing some road "testing" I'm pretty happy with it. It's not quite a supercharger for my suspension, but it seems to "take a set" in a corner a bit quicker now, and from my slalom-ing of the paint stripes in the road, the L-R-L-R transitions now feel the same in each direction, and the "transition time" seems to be shorter, so that's cool. Granted...all of this is qualitative, and potentially "I just put this expensive part on my car and I need to justify the cost" sentiment, so take it with a grain of salt.
"But Mark, isn't lightness the goal for autocross? Why did you put that big heavy Watt's link on there?"
Surprisingly...there isn't a lot of weight added. Between the panhard bar, panhard brace, and stock diff cover coming off, and the actual reduction in overall length of tubing with the watt's, I'd be surprised if the weight difference between aftermarket PHB, stock diff cover, and stock PHB brace and WL Watt's is outside of 5-10lbs. Seems like the Watt's diff cover is the most substantial part, along with all the extra hardware. Again...musings...but it's not as much of a weight gain as I initally expected.
And I've begun to stockpile 315/30/18 A6's. This is 10 of them, all scrubs of varying levels of wear (one really good set, one pretty ok set, and one May-Pop set), and there are 2 more tires down in Dallas that I need to go get sometime. This will give me three sets...and I'll buy some stickers for 2015 Solo Nats, which, incidentally, just had their 2015 dates released. Sept 1-4....book your hotel.
New springs came in. They're....well they're stiff. These will go on this week and I'll test them Sunday...hope for good results. The front is going to get lowered as much as possible too, probably another inch over where it is now.
Stuff to come off the car this week-
-Roll bar (~65lbs)
-Tow hook (~5lbs)
-Brake ducting (~2lbs)
This should get me down to the low 3400's in autox trim, and between the light battery, some future exhaust work, maybe the brakes, and a couple control arm swaps, I'm looking to dip into the 3390-3410 range. Doable? Maybe....will report on weight probably in December, when most of the major weight reduction is done. Been thinking about ditching the WL front swaybar (solid spring steel) in favor of a hollow one as well. The rear is staying. The ability to adjust it in less than five minutes without jacking up the car is a compromise I'm willing to live with. Of all of the "quick and easy" tuning I can do, the rear bar stiffness seems to be up there with shock rebound and tire pressure as far as the magnitude of impact on the car an adjustment has. I'm willing to live with the extra weight for that.
This thing is HEAVY!!! It will go back in eventually...once I'm done with the autox thing in this car. The medium term plan is to do probably two Solo Nationals in this car, then acquire a Lotus 7 clone and turn the Mustang into a full blown track/race car.
ESP rules question for the peanut gallery- can I remove the windshield washer fluid reservoir? It's not on there right now, and if it doesn't have to be I'll leave it off, but if it does, it goes back on. Thanks!
