kelloggs crank? AA3750X56B1
tmcolegr
It's All About the Build
Central, FL
correct for what ???
that part # is a forged 3.750" stroker crankshaft for a 4.6L
thump_rrr
Montreal Qc,
Is this the correct crank for a 2006 gt AA3750X56B1?
No.3.543 is factory stroke.
That's a 3.750" stroker crank.
It is typically called a 298 stroker crank.
3.552/2=1.776
1.776*1.776=3.154
3.154xPi(3.14)=9.909 (Bore)
9.909*3.750=37.159 (Displacement of 1 cylinder)
37.159*8=297.27Cubic inch.
If using that crank you need to order connecting rods and pistons designed for that stroke.
v6tungsten
Wylie, TX
3.552/2=1.776
1.776*1.776=3.154
Yea I already have the livernois/manley rods (5.85")
think the specs on the rods are:
  • Center-to-Center : 5.850"
  • Big End Bore : 2.125"
  • Big End Width : .940"
  • Pin End Width : .940"
  • Pin Bore : .8671"
  • Weight : 612 grams
Dino Dino Bambino
I have a red car
Cyprus
3.552/2=1.776
1.776*1.776=3.154
It becomes 297.61ci (298) when you factor in a 0.002" cylinder hone with pistons to match a 3.554" bore. Add a 3.80" stroke crank and the displacement becomes 301.58ci (302).
Anyway, the only thing I've ever owned that was made by Kelloggs is a packet of Corn Flakes. ;-)
