Whiteline UCA
No, you get almost no NVH from LCAs unless you're using rod ends or the bushings are completely shot.
What UCA are you using?
Perhaps I'm misreading but are you saying that you end up with more NVH if you upgrade your sway bar end links along with LCA's ?
No, he's stating that even with upgraded poly bushings in the LCAs, you still do not get much NVH from the LCAs UNLESS you have LCAs with rod ends (which utilize a spherical metal bushing).
This.
Also, I run rod-ended LCAs, and they don't contribute NEARLY as much NVH as my rod-ended UCA.
