07BLACKStang
Austin, TX
Wired my garage door opener to my brights switch. Probably one of my favorite mods and it was free.
The01Cav
Installed new signal lamp housings, re installed splash shields, and swapped out my Sportlines for H&R Race Springs. Tomorrow is mount/balance and install new wheels and tires.
bujeezus
Alabama
I just sat and stared at my car trying to convince myself I need those Downforce 20s LMR has on sale. It didn't work...
07BLACKStang
Austin, TX
Probably just tapped the brights wire and stepped the voltage down and hard wired it into the transmitter. I'm guessing though. I took my factory custom window switch panel and turned the extra switch into a trunk release. I thought that was pretty cool.
This is pretty much correct. My transmitter was 12v so I didn't step the voltage down.
You just solder a wire to make the button active all the time then solder wires to the + & - terminals. Tap into the brights on the headlight harness and you're done.
Works like a charm. I can give more details if interested, but it was pretty easy. Just had to look up the wiring diagram to find the correct wires to tap.
Also installed H&R super sports with Koni yellows and some relocation brackets. Hooks much better now.
dark steed
Resident noob
Winder, GA
Washed it
cbass
m̶o̶u̶t̶h̶s̶e̶x̶
Rochester, NY
Catch can and Roush CAI install. Laid some sealant on it, letting it sit overnight, then either some colonite or some nice carnuba over it tomorrow.
The01Cav
Got my new wheels and tires mounted and installed them on the car and took it to a local cruise night. Felt great to be back behind the wheel.
TenSpeed
Boss 227..every damn time
Michigan
Swapped my new Lethal O/R X on. Also uploaded the Lund 93 Cam Tune. It sounds so nasty. ��
The link you posted to the sound clip came back like this:
Error 404.
Whoops, looks like this page doesn't exist.
KatoS197
Addison, TX
Error 404.
I didn't post a sound clip. I accidentally typed an emoji out of habit.
I'm assuming you'd like to see/hear a clip?
Gabe
Whippled Coyote
That was another way of saying "Where's the fkn audio clip?" without being so nice :)
