AnotherS197GT
Serial Valve Dropper
I'm sure many of you are aware I've had nothing but valve train issues from 3V motors. Stock or modified, they just don't seem to like me. After having 2 separate issues in the last 3 months, I've decided that 3V life ain't for me! Instead of trading the car in and buying a Coyote, I've decided to swap the car instead. My car is just about paid off, so it seemed smarter to me to swap an engine into a paid for car with a bunch of suspension mods and personal touches vs trying to jump into a new payment.
So far I've budgeted around $4,000 for the swap, but I'm sure it will run over. I'm taking a trip to Chicago at the end of next week, and I would at least like to have the car running (probably not driving) before I leave.
The plans:
2014 F150 Engine:
30k miles out of a truck that was wrecked. The engine looks pristine in all the pictures. It appears to be complete from pan to throttle body. My plans right now are to leave it alone. The only differences I've found between the F150 and Mustang are the oil pump (may get swapped. Engine has a 6 month warranty, so I'm inclined to not void it) intake cams, and compression ratio. The truck is 10.5 vs 11 in the Mustang. I'm thinking with the Mustang exhaust and a tune, it will make for a fun car.
Intake/Exhaust:
Stock coyote air box and tube. Stock Coyote manifolds, cats, and H-pipe. This will more than likely be adapted to the 3V OTA pipes and run with either FR500s axle backs or GTBs.
Fuel system:
For simplicities sake, I'm going with a return style fuel system. This will be easier than trying to make a Coyote pump work with the 3V or make the 3V pump work with the Coyote PCM. The plan is to run a C5 Corvette fuel filter in place of the stock fuel filter. These are actually pretty neat filters. They have an internal 58 PSI regulator on them and a return line coming off. I will be running my return line right back to the stock 3V hat. To feed the rails, I will be running -6 AN lines from the filter. Fuel pump will be a Walbro 255. All in all, the system has cost me about $250-$260.
Accessories:
I will be using the Power By The Hour Coyote Swap kit. Reusing the 3V alternator, A/C compressor, and PS pump. The bracket kit looks to be extremely well made, and I can't wait to get my hands on it. In order to use this kit, you will need to use a 2014 MUSTANG timing cover. The F150 will not work with the PBH kit according to the folks over there. Good news, it's only about $100. Big shout out to Frank at PBH for taking the time to talk to me.
Engine Management:
The smart thing to do would have been to pony up for the Control Pack from FRPP, but I never do the smart thing. I will be running a stock 2012 PCM and making my own control pack. Of course, I will be getting lots of help from someone MUCH smarter than myself. Fortunately, I don't think the harness will be too complicated to make. Time consuming, yes! Difficult, probably not. Unless I've been drinking too much.
Driveline:
Stock coyote flywheel (~$120 new, what a steal!), TR3650 with my used Exedy 400, stock 3V driveshaft.
I started ordering parts Monday, and I expect to have most of what I need to get this done. Big props to all the people I've been bugging over the last 3 days to get parts shipped out and ordered up. So far the O2 sensors, timing cover, alternator pulley, and some misc stuff have shown up. Most of my fuel system should be here tomorrow/Friday. The engine is slated for delivery Friday. 2 day freight from NY to FL was surprisingly cheap! I'm really trying to get everything I need to get engine in the car and *hopefully* started this weekend. Then finish the other stuff up throughout the week.
I guess we will see if the car is bad luck and eats valves, or if it's 3Vs that eat them for me. Either way, my chances of valve/follower destruction have gone up 33.3333333333333333%!
Now, I'm going to get off my ass, get this car into the garage, and start yanking a 3V motor!
The plans:
2014 F150 Engine:
Intake/Exhaust:
Fuel system:
Accessories:
Engine Management:
Driveline:
