The01Cav
Loosely installed a Roush bumper and bullitt grille on my mustang. Looks AMAZING!
Shotokan1509
CT
Brrrr final wash of the season, just above freezing with a breeze
06 T-RED S/C GT
Carnegie, PA
Although I really like Torch Red.. If I had the chance to go back and do it over again, I would've selected Sonic Blue instead.. As there's just way too many Torch Red Mustangs where as Sonic Blue was only available on the S197 during the 2005 model year..
Davidx9x
Essex County, NJ
Installed boss gauge pod, gauges and did oil change. Looks pretty good, i like it!
Passed emissions today. Not a big deal to some I'm sure. Sniffer at idle and obd. New n/a specific cams come on Thursday :)
Thenorm
Autocrosser
nothing, theres 4 inches of snow in the road. this is quite rare for Vancouver.
I could get out my driveway (its all downhill) but that would be it.
bujeezus
Alabama
Test fit my new wheels on the front. I'm worried I'm gonna rub tire. These things are wide as fuck! What's the narrowest tire you can run on a 10" rim? 255, 265?
oldVOR
Northern Virginia
What spec wheel?
Typically, an 18x10 would get a 275/40
What chin spoiler are you running?
Changed the oil and rotated the tires. Ford's computer is definitely not user friendly. I found where it shows the oil life percentage but that isn't where you reset it. You have to back out of that menu, go to another menu called 'settings' and find the oil life reset item in that menu. I may just go back to putting a small sticker on the dash with the mileage written on it.
travelers
Eastern Pa
Installed boss gauge pod, gauges and did oild change. Looks pretty good, i like it!
The gage pod looks good. I just got one and still deciding on what to put in and if I want to cut a hole in the dash or try and run them forward into the defroster duck. how did you mount yours?
Davidx9x
Essex County, NJ
Thanks bud, i really liked how it turned out. I eventually will get a wideband air fuel ration and take the voltmeter out.
It's held down by 4 screws. You can try to hold it with double sided tape, but it will not stick. I tried the tape before putting holes with no luck no matter how much i cleaned the surface. I didn't see how the the wiring and hosing can get around since it's cased in. Might be able to run it through the air windshield air vents but it may look cheezy having everything exposed.
