46addict
13726548
Provided that your lean protection module was doing its job, we can rule out lean mixture. What did the plugs look like? Any of them appear different than the others?
Or sell me your crank! I'm looking for one. Just pm me the info on it!!
Yes OEM 3v gaskets,What head gaskets are those? They look stock, are they std 3v gaskets?
HRE (Hameetman Racing Engines)a local but very good, very high-end shop. They do mostly blown offshore race boat engines, LS and Mod motor stuff. There's also a Pro-mod team that runs out of that shop, a very good one at that. I have no complaints about HRE, thank you very much for the suggestion though!Who is doing your machine work for you? Have you contacted Tim at MPR? He is on Boynton Beach and is a Mod Motor Specialist. 561-588-0188
I know you said they are Ford head gaskets, but are they std or overbore gaskets?
STD size.
IIRC you are ,030 overbore, are you not concerned about piston to gasket contact? I always use the Ford overbore gaskets. You could have had a gasket failure due to piston contact and then that caused a lean condition in that cylinder. Now, why the entire block split to pcs is what I dont understand. Its not from 20 psi boost, my coolant cap is a 23 psi cap.
What was your timing advance at?
I asked about decelerating with the torque convertor locked up and he said that's extremely hard on the motor, said if I did that with a pro-mod motor all the rods would have instantly blew right through the sides of the block! That's probably why there's some shadowing on that rod bearing.
I IDK..
When you said you did that, that's what I thought. My car is tuned by Lund with a 2.3 whipple at 7psi and when I sent him my data logs from a run on the street, when I let off it would go from 11ish right to 14+. So when you had the converter locked up and did engine braking it probable went lean.
The guy that I crew for with the Cuda SS/AH car is stick and he kicks it into neutral then clicks the engine off and brakes it with just the foot brakes from 160 and no chute.
I think the pro-mods use alum. rods which don't like deceleration
im assuming that includes manuals, should shift to neutral at the top end of the track, and brake from there?
That's exactly what my machinist said, the pro-mods (or other high power shit) shift into neutral before lifting to prevent the alum rods from flying away. He said they have lock up convertors too, but if you leave them locked up and lift it's game over. I'm pretty sure everything was fine until I crossed the traps and lifted with the convertor still locked up, it felt like a normal pass then when I lifted I looked in the rearview and saw a smoke screen. I bet that's the culprit.
I just measured all my pistons, and found 2 more that are collapsed plus the #8 one that melted, so if I end up going alum block again I'll need 3 new pistons, I wonder what that would cost, might be better off to buy a new set of 8.
Really? I engine brake all the time. Are you saying this is a strain on the engine??
I wouldn't fuck around, I would go with 8 new pistons. I wouldn't trust the rods either.
o2sys, id imagine engine braking for us on the street, just using it to gradually slow down a little, is probably a lot less stress than running max RPM's under full load, and suddenly going from ALL the power, to ALL the vacuum and having all the strain, but in the opposite direction
I would also carefully label the injectors and have them flow checked.
I will say I have not seen to many guys doing coatings in the 3V world, but it was dirt common in the powersports world for guys modding motors for big power.
