wdavid531
I'm upgrading valve springs in my 06 GT and was wondering if anyone had an tech tips or tricks on the best way to do it. The compressor I'm using is from Euroexport and can't be used with cams installed. I'm currently installing and removing the cam between each cylinder to try and keep the timing because I would like to avoid pulling the timing cover if possible. Any ideas that would be easier or save a little time?
