i got the power stop z23 evolution sport and I like them, great for spirited daily driving but not quite race ready.
Thank you for the link to this other thread. I looked through that one but very little useful information other than "buy better tires" which is not at all what I'm looking for at this time
Thank you for the help.
Problem is your not going to really gain performance in terms of stopping power, common misconception. The "performance" by using different oem replacement pads and rotors is things like have cooler looking rotors that dissipate heat better, pads that don't fade as easy when hot or pad material last longer or make lest dust than others or less noise or more aggressive bite material etc. You can lock up any standard brake and rotor quickly, its the tires that stop the car anyway. The brakes turn rotational energy into heat and slow the wheels and the friction of the tires on the road slow the car down. Things that actually allow the car to stop quicker is less vehicle weight, lighter rotational mass (lighter wheels and rotors), tires with more contact patch on the road and better traction, larger diameter rotors and pads with more surface area. A stainless brake line upgrade from caliper to hard line is a popular mod, again won't measurably affect brake performance but does improve brake pedal feel.
My suggestion go to rockauto.com and get some good oem replacement pads and rotors that suit your needs and wallet.
GOOD tires, stock rotors, decent pads (ceramic pads from Autozone are actually pretty good pads), fresh brake fluid.
Your brake fluid is a must at this point, also expect to do the front and rear brakes at nearly the same time as these cars wear brakes very evenly front to rear.
I now buy the StopTech pads from RockAuto. Great value/performance.
When I did my brakes the first time I bought a kit from TPS Motorsports which included
HPS-HP Front & HPS-HP Rear (HP Street) Hawk Performance Brake Pads. * 3 Pints Motul High Temp Brake Fluid. * TPS DOT Approved Stainless Steel Brake Lines. * TPS Slotted/ Dimpled Rotors (2 front & 2 rear).
Along with StopTech pads I'd go with Centric premium rotors. Stoptech and Centric are the same company but that is not to say that your rotors and pads need to match companies. Rotors are a little better than OEM and about the same price, listed in the Daily Driver section on Rockauto.
After you get everything replaced make sure you bed the brakes properly. It's process for matching the pads to the rotors and increasing the stopping performance.
The stock brakes are fine if you're not autocrossing or doing track days. Get some decent tires.
really, guess our definitions of useful is a lot different
LMR has a set of 4 Centrics for $205. They are cross drilled but they will be fine for street use.
https://lmr.com/item/LRS-61086-KIT/brake-rotor-kit-drilled-slotted-0514-c-tek
EBC crossed drilled rotors wit hawk pads I have this for my DD Bullitt great brakes
Bought a set of ATL rotors off Amazon for all four corners last March. I bought them mostly for looks as the hats and outside edges on my stockers were all rusted up.
Amazon.com: ATL Autosports Performance Brake Rotors FRONT PAIR Fits 2008 Ford Mustang [Bullitt - V8 - 4.6L ] ATL54134-05SOBZ: Automotive
So how many of those had a suggestion of ROTORS? I appreciate the help, but as an admin being like this going back and forth isn't exactly helpful and is far less than welcoming to a new(ish) member looking for a basic referral which other members (that aren't admins) have been very helpful with.
Don't bother replying I'm not going down your rabbit hole any further. Thanks for trying to help.
Just get some centric blank rotors. You'll see zero difference between those and "high end" rotors unless you're actually racing.
Thanks to stkjock for linking to my suggestion in the other thread. I'll repeat here. Centric rotors are the way to go. Avoid drilled, slotted, drilled and slotted, etc. unless you just want cool looking. It adds little if anything to performance and a lot to the price.
nearly everyone that replied suggested sticking with OEM rotors
if you can't search, at least learn to read
The irony of you telling me to "read" when you didn't bother reading that I had actually seen that thread before (before the admin goons linked it - it just didn't have the advice in it I was looking for) is simply hilarious.
It didn't have the recommendations that I was looking for that others in THIS thread have so far provided so graciously.
Man I love keyboard forum warriors sometimes.
