4.63v tick
Heaten m90
I also have a set of stock cams 200 $ shipped. Or cams and new phasers for 400 plus shipping
teeje
Ohio
Alright well none of the issues stated were the cause of the problem.
One of the cam bearings was toast. Motor torn down revealed scoring on the main bearings and some scratches and hot spots on the rod bearings. Engine is getting replaced with an 80k engine (lowest the warranty company found I guess) 3500$ worth of parts and labor and I only lay around 300 after taxes
What really grinds my gears..i just changed the oil to royal purple full synthetic and used a Ford filter and changed the speak plugs. Spark plugs will obviously be re used I only out maybe 20 miles on them. I should have it next week and then it's time for its new fuel filter. Any other maintenance items I should look for?
Sent from my SM-G955U using Tapatalk
What motor do you have? The 4.6 3v doesn't use cam bearings.
teeje
Ohio
Car is almost done new engine here, old is out, new clutch kit going in and all done
